Swapping crank tone rings
I have a 24 tooth ring on the crank and want to run a later model computer to go with a 6L90E.
Engine is entirely disassembled. What needs to happen?
The existing wheel is removed with heat and the changeover unit is heat shrunk back on. Easiest to do with the tool but also possible to do without.
