Crank key come with the LS2 timing set?
Old Jun 3, 2010 | 01:12 PM
1madss's Avatar
Default Crank key come with the LS2 timing set?
Should the crank key for the lower timing gear come with the LS2 single row timing set? If not does anybody know the part number for just the key?
Old Jun 3, 2010 | 03:14 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
No, it does not come with a new keyway. Grab GM#12561513 if you want to replace yours
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 3, 2010 | 05:51 PM
1madss's Avatar
Thank you
