Cam phaser bolt - Source?
Old Jun 6, 2010 | 04:22 PM
68Problemchild's Avatar
Talking Cam phaser bolt - Source?
Anyone got a source for a cam phaser bolt? 2007 escalade L92.
I found the phaser, installed the rev limiter, now just need a bolt.
Thanks!
Old Jun 7, 2010 | 08:38 AM
cam's Avatar
cam
Its a VERY hard thing to find. I've had one on backorder for two and a half months now. Theres a few different types of phasers out there as well as this info is still very much in the dark and I wonder if thats what makes it tricky to get your hands on a new one. They are a TTY fastener but they are technically known as a "valve" in GM part listings. I;ve seen a few posts where guys have re-used them on cam swaps and it seems to work. I might go that route myself if I cant get my hands on a new one soon.
Post up if you find a source with them in stock please.
Old Jun 7, 2010 | 12:03 PM
tippy's Avatar
I'm still looking for one as well...
Old Jun 7, 2010 | 01:32 PM
Just so you know, on re install, I read an article where it had it at 48 Ft.lbs + 90 degrees which it said was a total of 154 ft lbs.
Trust me, it will snap at 100 Ft lbs on reinstall.
Old Jun 8, 2010 | 08:10 AM
cam's Avatar
cam
I havent checked the torque spec yet. Hope alldata has that info covered.
As a small aside it seems everytime I read about VVT phase I see different numbers published in regards to total advance/retard for each set up. Interesting...
Me thinks there is a LOOOOOOOONG way to go in fully extracting the most out of these things.
Anyways Im still on the hunt for a new bolt/valve so ANYONE???
Bueler??
Old Jun 11, 2010 | 02:50 PM
Default Phaser valve
Finally got one at the GM dealer. You need a vin#.
Vicotry Lane Motorsports in Fort Myers Fl.
Old Jun 11, 2010 | 02:58 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
If you called us up, you would not need a VIN . It is not JUST a bolt, but a "valve" as well. It is a little complicated. They were on backorder for a little while from GM. There is a difference in the part for the VVT and for the standard single bolt. FYI.
Old Jun 11, 2010 | 03:51 PM
cam's Avatar
cam
I spoke with someone at SDPC today oddly enough. I've had one on order for over two months and I was told they just arrived and I should see it within a week. Heres to hoping
I received everything else I ordered from SDPC though. Went to the wrong address unfortunately. **** happens whaddya gonna do?
Cant wait to get this thing going though
Old Jun 11, 2010 | 04:30 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Great. I am glad we got you fixed up. Sometimes Gm does some funny things.
