418 Shortblock. Pistons hitting head?
The Driver side head had no markings?
I bought this shortblock, head gaskets from a supporting vendor..
Any suggestions on what could of happened?
It's kind of hard to believe you wouldn't hear the knocking sound if that was what was happening......of course I'm not an engine builder by any means
Im assuming the pistons pushed the head up,and gasket let go..
The letters FWD and an arrow are laser etched in each piston..
They have imprinted FWD into the passenger side head.. Nothing on the driver side head..
The opposite of this is having heads with huge chambers and valves hitting
the cylinder wall.
Sorry for your loss. Post up your results. This is interesting to look at.
Like the other guy said, i've had motors burn holes like that when using nitrous.
Usually just melting plugs away, but often scarring internal stuff.
Honestly, I've seen the pistons hit the heads a lot worse and not cause gasket failures. Then again, they probably weren't run as long since the problem was much more obvious. I'd try to take a measurement and see how far the pistons are out of the hole on both sides and see how much quench distance you had when the engine went together.
If the vendor just built the shortblock, you may be SOL, unless you can prove they recommended those gaskets. Even then, it's gonna be a longshot.
Kurt
