part throttle misfire
driving around town or on the highway steady state cruising every once in a while i get an intermittant misfire/dropped cylinder. it doesnt happen often, but i can feel/hear it every couple of minutes of cruising.
any questions ask, any ideas where to look let me know.
02 sensor could be acting up too. OBDII scanner is needed to see how they are switching while the engine is running at operating temp.
If your not getting any misfire codes its probably not a coil issue.
the misfiring only happens between 1500-1900 rpm
