What is the correct way to install valvesprings?
Old Jun 22, 2010 | 08:33 PM
pHEnomIC's Avatar
Default What is the correct way to install valvesprings?
I installed prc duals for my torquer v3 and followed the directions on ls1howto.com. It simply involved putting the piston to the top, compressing the spring and then switching it with the new setup.
I have broken 4 valvesprings so far, so something is not right.
What is all this talk about checking installed height and preload. Why didn't the directions have any of this.
Old Jun 23, 2010 | 05:00 AM
vettenuts's Avatar
You have broken four valve springs? Have you dropped or banged any of them? What tool are you using? If you are using one of those tools that has the two claws that grab the spring throw it away.
When you install valve springs you should figure out your seat and open force. The get the seat force, you need to figure out the installed height. Once you have the installed height requirement, you need to determine the clearance to coil bind and the clearance between the retainer and seal. Installed height is adjusted with shims.
LS1howto is not an end all be all factual web site. It is a great site for some general information, but user beware. There are several major issues with the methods used on that site, just do a search of crank thread problems from following the methods for removal and installation of the pulley. The Yella Terra write-up is wrong as well. It will give you some methods to slap in parts, but it certainly doesn't provide information on setting up a valve train.
Old Jul 15, 2010 | 09:00 PM
pHEnomIC's Avatar
How exactly do you find the installed height? What other steps are necessary to verify correct installation.
Btw, i am using tims tool which is similar to the crane spring install tool.
Old Jul 15, 2010 | 09:19 PM
KCS's Avatar
KCS
Moderator
What valve seals are you using? You may be having problems if you reused the OEM 1pc style vale seal.
Old Jul 17, 2010 | 01:13 AM
pHEnomIC's Avatar
I used the 2 piece ones that texas speed supplied me with.
