How long are Gen 4 head bolts?
Old Jun 25, 2010 | 05:35 PM
Hotrod406's Avatar
Default How long are Gen 4 head bolts?
Can someone measure a set for me? I need to know the under-head length to see if they will work in my application (not LS1). Thanks!
Old Jun 26, 2010 | 09:22 PM
Hotrod406's Avatar
54 views and no one has a bolt he can measure? I thought this would be a slam dunk. Somebody's got to have something.
Old Jun 26, 2010 | 11:08 PM
hotswap's Avatar
I just happen to have a brand new set of OEM head bolts for an LS2 and i just walked out to the garage and measured them. The long center and lower bolts are 4 5/16'' or about 110mm and the smaller upper bolts are 2 1/16 or about 52mm. These measurements are from tip to tip. I hope this helps.
Old Jun 26, 2010 | 11:26 PM
Hotrod406's Avatar
Thank you very much. That rules out Gen 4 bolts for the Northstar that I need to fix. Several of the head bolt threads pulled out of the block and I wondered if I could use 1/2" head bolts for a Gen 4 (the next size bigger than the stock 11x1.5 Northstar bolts) instead. It doesn't look like that's going to work.
Does anyone know of a motor that has 20 5.5" long 1/2" head bolts? I thought Ford Cleveland but those are only 4.5" long.
I'd rather use 1/2" bolts or studs than the inserts.
