ls2 into my camaro
Old Jul 12, 2010 | 07:09 PM
SilverBulletZ's Avatar
Default ls2 into my camaro
what would i need to do to drop a ls2 where my ls1 sits?
Old Jul 13, 2010 | 11:40 AM
1nasty86's Avatar
Turd Gen Guy
everything should bolt up the only difference is the knock sensors are on the sides of the block vs. under the intake, the cam sensor is located on the front timing cover vs. behind the intake and depending on what year ls2 you get it either has a 24 or 58 tooth wheel. the 05 still has the 24 tooth wheel. lingenfelter makes a converter box to run the 58 tooth with the stock computer hope this helps
Old Jul 13, 2010 | 01:04 PM
doesnt sound too hard and the ls2 is out of a 05corvette
Old Jul 13, 2010 | 05:16 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
If its out of an 05 then you won't even need the converter box. GM didn't start changing reluctor wheels until 06. We have those conversion parts available in a package for $369.99. Give us a call or send me a PM if you need the package or have any further questions!
Old Jul 13, 2010 | 11:28 PM
ill keep that in mind
