arp headstuds. to loctite or not to loctite?
Old Jul 15, 2010 | 08:17 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default arp headstuds. to loctite or not to loctite?
should i put some loctite on the end thats going in the block? i dont think i will ever plan on taking them back out, unless i put some rods and pistons in..
this is goin in a turbo motor BTW!
Old Jul 15, 2010 | 08:40 PM
JBarron's Avatar
Nope, just thread them in hand / finger tight. You can use Loctite, but it is not necessary, and they must be torqued before the Loctite dries. The studs need to be able to wiggle a little when you torque them. Make sense?
Old Jul 15, 2010 | 08:50 PM
Randy WS6's Avatar
I did use loctite on my studs, and when i screwed them in the block and bottomed them out ,i backed them out 1/4 turn. That's what ARP told me to do.
Old Jul 15, 2010 | 08:59 PM
JBarron's Avatar
The only thing I would consider, is that if for some reason a stud is ever over-torqued, it will need to be removed. Also, if they aren't Loctited in, you can take them out and measure the length to see if they are stretched beyond acceptable limits.
