Needing some help on decisions
Old Jul 17, 2010 | 11:02 PM
InbredStang's Avatar
Default Needing some help on decisions
I am planning to build a ls2 motor i have an idea of what i want in brands but not sure on sizes and such. I am was wondering if you guys can help me out.
Engine Components
Heads: AFR
Rockers:Harland sharps
Push rods:Hardened
Valves: Manley
Springs:Livernois
Camshaft:244/242 HPE mega deth
Intake Manifold: Ls6
Tb:fast 70 or 90mm
Pistons,crank,c-rods: Eagle
Ignition
Battery: Optima yellow top
Plugs: NGK
Distributor:MSD or Jegs
Wires: MSD or moroso
Fuel
Fuel pump: ?
Fuel lines/supply: Jegs
Injectors: Accel lbs. ?
Exhaust
Exhaust: Borla/Slp/Spintech
catback/ x or h pipe
Headers: kooks/hookers 1 3/4
So i am looking forward to see what you all think and just say if something if you think i should get something else instead.
Old Jul 17, 2010 | 11:38 PM
AES Racing's Avatar
fuel pump: what kind of car? I'd say Walbro 255 intank
Injectors, accel would be my last choice, most people i've seen use them find out they're not the flow number advertised.
i'd use FAST 36lbs/hr injectors
Old Jul 18, 2010 | 11:03 AM
87silverbullet's Avatar
I wouldn't use Harland sharp rockers and I wouldn't put an ls6 intake on a good head and cam as you are using.
Old Jul 18, 2010 | 04:18 PM
I am planning to put this engine in a 88 fox body. thanks for the suggestion I will probably go with them injectors and i will use that pump.
