ls 302
Old Jul 31, 2010 | 07:45 PM
crw3673's Avatar
Originally Posted by Tninl98
Could try giving Callies a call and see if they could build you one. They just built me a stock stroke Compstar crank. I had to pop off a reluctor from an old crank i wasnt using, send it to them and they built the crank for me.
can i know ruffly, how much it cost you? i would really like to start to make a build sheet, with how much it would cost me?
Old Jul 31, 2010 | 08:10 PM
chevmech1969's Avatar
This is 500+ hp on a naturally asperated 302cubic inch chevy.
Usually there is no replacement for displacement. but i think this defys the rules.
it helps they put arao engineering heads on it.
http://www.youtube.com/watch?v=JygTz...layer_embedded
Old Jul 31, 2010 | 08:18 PM
cutlass_455's Avatar
I dont think it defies the rules....I think it follows the rules, ie peak HP at 7500 RPM. I wont even get into the 32 valve heads.
What lots of people dont really understand is RPM is a major key in making big HP, but its a double edged sword cuz RPM is hard on engine parts and expensive to buy.
Old Aug 1, 2010 | 02:38 PM
Tninl98's Avatar
If callies is willing to build a compstar crank in the stroke you want you will probably be looking at 1,000 more or less. Most likely you will have to order it through a local machine shop that has an account with them though.
Old Aug 1, 2010 | 09:01 PM
LSGunZ28's Avatar
Im sorry but this is not worth it... you can rev a 3.622" stroke well over 7k rpms... why spend extra money to go less stroke, if there are no displacement size regulations..
Old Aug 15, 2010 | 09:19 AM
crainholio's Avatar
Originally Posted by crw3673
so does anyboy know how to go about making this engine? would really like to have something different and unique...
...and slow as a pickup truck full of fail. If you want high revs and no power, Honda has what you're looking for.
Old Aug 15, 2010 | 10:29 AM
86MonteSS's Avatar
i think its a cool idea if you want nostalgia. if you are just looking to spin it to the moon, RobZ has a 388 thats revving to 9k
Old Aug 15, 2010 | 11:19 AM
WKMCD's Avatar
When I wanted nostalgia...I built a 427. I don't think there is anything more iconic.
Old Aug 15, 2010 | 12:48 PM
crw3673's Avatar
to each, his own ! if i would like to build a 302 camaro whats the big deal? why hate on me? or the project. if i was building a 454 lsx monte carlo, would that be consider ok?
Old Aug 15, 2010 | 01:35 PM
crainholio's Avatar
Nobody is hating, just pointing out the reality. If you find that hateful change your panties.
Old Aug 15, 2010 | 02:34 PM
Mumbles's Avatar
Originally Posted by IHEARTLS1
OP, why not just use whatever engine you have and put 302 badges on it or get 302 engraved on the valve covers with the coil packs relocated
Other than relocating the Coil Packs, please don't do this.
Old Aug 15, 2010 | 03:09 PM
  #32
WKMCD's Avatar
Nobody's hating. This is a performance forum and it's really contrary to give up cubic inches unless there is some class restriction.
All things being equal...a bigger motor is going to make more power.
Old Aug 15, 2010 | 03:49 PM
  #33
Pwebbz28's Avatar
I approve this post!!
Old Aug 15, 2010 | 04:13 PM
  #34
apexman's Avatar
I thought I remebered a 302 LS1 being done awhile back. Here is an article.
http://www.ttspowersystems.com/articles/7/index.htm
Old Aug 15, 2010 | 04:42 PM
  #35
Nitroused383's Avatar
Look up info on Daytona Prototype cars. Had to use GM intakes / heads, 302 cubes, 7000 rpm limit. These cars were putting down 500 rwhp with truck intakes and ported 243 heads.
Old Aug 15, 2010 | 06:40 PM
  #36
crw3673's Avatar
eat a dick crainholio
Old Aug 15, 2010 | 07:48 PM
  #37
crainholio's Avatar
This comeback is unsurprising given the topic...seems the engine isn't the only slow part.
Old Aug 15, 2010 | 08:09 PM
  #38
KCS's Avatar
KCS
Moderator
