Crank Position Sensor Clearance #'s
LS3 Block
Callies 4" Stroker Crank 24T
Factory LS2 Sensor
This is in my GTO.
I am getting misfiring under load and this may be the problem.
It doesn't miss on the dyno, only on the road under load.
Backfires and stumbles fairly bad.
Mainly in 4th, 5th and 6th gear.
All new plugs, wires, coil packs, coil pack harnesses, ect...
