LS7 injectors?
Old Aug 10, 2010 | 09:24 PM
99RedHawk's Avatar
Default LS7 injectors?
Will the ls7 injectors work in a fuel rail with 14mm o rings? Specs show 14.5mm o rings.. Is it the body size difference or just the o ring that can be changed?
Old Aug 10, 2010 | 10:16 PM
Whistler's Avatar
Sawzall and Welder Mod
Brooke? Is there a conspiracy or a coincidence that you and this guy show up at the same time?
https://ls1tech.com/forums/racers-lo...599-howdy.html
Old Aug 11, 2010 | 09:54 AM
99RedHawk's Avatar
Yes, it is me but not sure about any conspiracy..
Anyone know about the ls7 injectors? Can I just use 14mm O rings?
Old Aug 11, 2010 | 10:20 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Going to put them into an AMG ? Good to see you back Brooke. I'm sorry I don't have an answer for you. But, it is good to see you an Colonel both on the site in the same week. Its like old home week. All we need now is Raughammer...
Old Aug 19, 2010 | 05:14 PM
1madss's Avatar
Wow. Have not seen so many 2001 join dates in awhile
