LS2 Rocker Install Questions
I am installing putting a set of used Harland Rockers that have been clearanced for LS6 style heads (not specifically mine) How much clearance amd I looking for where the rocker rises back up and clears the sidewall of the head. Visual thickness description prefered (ie. credit card, business card)
Also, I am installing the rockers via the Yella Terra Rocker writeup. I understand I am looking for a final <360 degree seated height to not require shims/washers. Mine seems to be completing this step with only a 45 degree turn. I wondered if I was doing something wrong or if this was normal.
Thank you in advance for any help you can provide.
Brandon
