Head gasket question
Old Sep 15, 2010 | 11:30 AM
Y2KSS's Avatar
Default Head gasket question
I'm putting my 98 LS1 PP heads on a L76 6.0 liter block and was wandering which head gasket would be recommended for this setup?
Thanks
Old Sep 15, 2010 | 12:27 PM
1SLwLS1's Avatar
What specs do you want? Do you want the bore size? The thickness? The brand? Material? Are you trying to raise/lower/keep the same compression?
I would recommend the GM MLS 6.0 gasket for a good general purpose.
