oil pressure issue
Old Sep 27, 2010 | 11:19 PM
1nasty86's Avatar
Turd Gen Guy
Default oil pressure issue
ok i bought a ls2 off a guy on here. he said it was in great condition and ready to go. so i used my ls6 oil pump off my 5.3 reused the black o ring and pickup. proplem is at idle oil pressure is 20 lbs. driving it gets to 40. pulled it apart and the oil pump spacer had let silicone get into the oil track and cause the hole in the pump spacer to be smaller than normal. also i was told all gm o rings are blue. anybody have any ideas. my oil pump may have 4000 miles on it. and when i get off in it oil pressure stays around 40 doesnt rise.
Old Sep 28, 2010 | 12:35 AM
1nasty86's Avatar
Turd Gen Guy
also found out he was running royal purple and i put valvaline conventional oil in it to break the cam in... would this affect oil pressure??
Old Sep 28, 2010 | 01:23 PM
1lejohn's Avatar
Do you think that the pump relief port is open? My oil pump o-ring was blue. I pinched my o-ring and the pressure would only go to 40 psi and then drop off to 0 when I let off the gas.
Old Sep 28, 2010 | 09:53 PM
1nasty86's Avatar
Turd Gen Guy
my oil pressure doesnt drop to 0 though. and mg o ring wasnt pinched.
