Obligatory cam thread (404ci LS2)
The engine will run a FAST 90/90 and ported LS6 heads (around 11.2-11.4 compression). I plan on running dual valve springs in them as well. Pistons are -4cc. You know the rest for the bottom end.
The two cams I am looking at are:
- 239/247 .624" 114+4LSA
- 243/247 .624" 114+4LSA
The second one is listed as a blower cam but I've seen cams of similar spec work with N/A setups. I'm no expert on valve events and such and could use a bit of help. The split on the first one seems kind of wide to me for a cathedral port motor but they list it for them.
It's going in a 6-speed C5 and will mostly be used for street and road course work. Probably won't run above 6500-6700rpm.
If you guys have any suggestions on any other cam you like, post them up.
The cam is a relatively small EPS 238/250 .603/.612 112LSA (though it was ordered on a 113) ICL is 110... BTW the Comp LSL lobes have a very similiar profile to Geoff's lobes but I believe are slightly more agressive...
What I would really do in your shoes is to get Geoff to spec you a custom....
My dyno here>>> https://ls1tech.com/forums/dynamomet...-403-dyno.html
