locktite: yes/no?
Old Oct 25, 2010 | 04:25 AM
skatnkidd's Avatar
Default locktite: yes/no?
I'll be putting together my motor I just bought from TSP. Installing all the topend hardware, is locktite on the threads a bad or good idea? I've heard both. Builder please voice your opinions, thanks!!!
Old Oct 25, 2010 | 04:56 AM
Unertl42's Avatar
what exactly are you asking about? Rocker bolts? Head bolts? Little more info please
Old Oct 25, 2010 | 08:51 AM
disc0monkey's Avatar
how often are you going into the motor? changing valvesprings every 10k? or driving til it explodes at 250k?
i use red locktite on mine.
Old Oct 25, 2010 | 09:56 AM
Jon@Texas-Speed's Avatar
Depends what you are talking about. Maybe the rockers if anything. Covers and that kind of stuff don't need any. Heads bolts won't need any. I would put some on cam bolts, cam retainer plate bolts, etc. I would use blue also. Red always seems to need a torch to get it loose! haha...
Jon
Old Oct 25, 2010 | 02:39 PM
skatnkidd's Avatar
Everything minus the bottom end is being installed. I would be using blue.
Old Oct 25, 2010 | 07:21 PM
Whistler's Avatar
Sawzall and Welder Mod
How's it going? I see you've managed to ring up six or seven posts in the three+ years youve had that car
I personally use red loctite on the cam bolts, all 5 oil pump bolts, cam retainer bolts, chain tensioner bolts, and the little ones that hold in the lifter trays.I never have a problem removing any of them later with hand tools.
