Cam not going into new 402... any help?
Its a LS2 402, Callies crank and rods, assembled by TSP. Thanks for any help!
All the cam journals measured between 55.02mm and 55.08mm. I even tried installing the cam backwards just to see if it would go in further to help determine if the cam was maybe a little bent, but still gets hung up in the same spot.
I don't have another cam laying around to try but I'm sure I could find someone to loan me a stocker to try out, but it's not sounding like it's the cam, right?
I guess I'll give TSP a call on Monday morning and see what they suggest...
I brought my cam in to test fit when I picked up my block from the machine shop. It had a couple of spots where it was tight and wouldnt go in. The machinist had to remove some material on one spot of two cam bearings and it was fine. IMO the sleeve retaining compound that they use to secure the bearings swells a bit especially if it collects in larger quantities on one side of the bearing and causes problems like this. Maybe this is why you read about honing the cam bearings after they get installed?
With the bore gauge, the 2nd bearing (where its getting stuck) is a little smaller than the first bearing by around .0012" and its even a little more narrow than that when measured horizontally (close to .0015). But it still seems like its within the minimum bore clearance according to some reading I was doing, isnt it?. So I guess that would maybe point to the bearings being offcenter, not perpendicular to the bore, or misaligned?
Zeroed on narrowest point of the first bearing:
2nd Bearing compared to first bearing:
2nd Bearing bore measured horizontally:
This is how far the cam is getting in:
And it took some effort to get the cam in that far. It didnt get to that point and stop, it get stuck a little before that point, and took a little persuading to get in even that far.
also if they have the bearings out of order they will do the same thing. the bearing bores in the block vary in size. 1 and 5(front and back) are the same, 2 and 4 are the same and 3(center) is different than the rest. center is the smallest bore, 2,4 are a little bigger and 1,5 are bigger yet. if they accidentally put one of the 1,5 bearings in a 2,4 bore. then that will cause the i.d. to be too small also
best thing to do. knock the bearings out and install new. peace of mind
