thoughts on Callie's rotating assemblys
Old Nov 12, 2010 | 09:44 AM
427's Avatar
427
Mightymouse I believe has a Callies crank in his car, unless he changed it from the original build.
Kurt
Originally Posted by AutomagicLS1
had a discussion about this with a friend the other day. As much power as people are making on a stock crank IMO someone is pretty much wasting money on a high dollar crank if your buying a big bad crank for a motor under or a little over 1000whp. Now a good set of rods and pistons is for sure the way to go. Look at mightymouse pretty sure that car makes ~1300 also 98z28cobrakiller
Old Nov 12, 2010 | 02:03 PM
CraZee ZO6's Avatar
for sure stock crank is fine at the 800hp level.. compstar 1000...callies dragonslayer or magnum 12-1500hp setups
Old Nov 29, 2010 | 12:08 PM
freakyfastlsx's Avatar
best stuff hands down
