questions about lq9,lq4
Old Nov 11, 2010 | 07:24 AM
BOBS99SS's Avatar
Captain Double Post
Default questions about lq9,lq4
Ok I'm looking to swap my old ls1 for a lq4 lq9 block,I have a few questions,I know its a pretty straight forward swap,but my plans are ,to use my ms4 cam,ported stock 853s,and my ls6 intake,I do wanna spray a 100-125 dry shot,but will this block take this abuse,?, I was planning on doing rod bolts,but what else should I swap to make sure it last,I have talked to a lot of people that have just swaped in the iron block and rolled with it ,I do have a budget in mind but I wanna see what the cost is actually going to run me,I thank you guys for any help or info you could send my way,thanks and God bless,also I'm having a hard time finding a block around northern ohio if anyone has any leads let me know ,thanks guys
Old Nov 11, 2010 | 03:31 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
The internals on either of those motors should be able to handle that kind of power. Depending on the mileage on the motor you might throw a fresh set of lifters in it. Other then new gaskets you should be good to go!
