Need cam reccomendations.
Old Nov 24, 2010 | 10:51 PM
IDRIVEAG8GT's Avatar
Default Need cam reccomendations.
Hey guys I'm new on this Forum, and I have a question for you LS engine junkies. I've got an 08 G8 GT with an MP1900 Maggie @10LBS, Roto Fab, and some other goodies, that I'm pulling the heads off of soon to do a lifter conversion on because I'm tired of the horrible clattering of the DoD's. I've also got some 1:8 Yella Terra's on the way too that are prototypes. I've got a little extra change and I'm highly considering doing a cam while I've got the engine torn apart. I hear that Lingenfelter makes awesome Supercharger cams, and I was wondering if they make a cam that lopes just a little bit that I won't have to swap TQ Converters for. My G8 stalls under WOT @2300 RPM.... What do you guys think? This possible? Thanks for any suggestions.
-Robbie.
Old Nov 26, 2010 | 09:23 AM
87silverbullet's Avatar
Talk to Bob@BruteSpeed he might be able to help you and Speedinc carries some good blower cams. Good Luck!
Old Nov 26, 2010 | 12:11 PM
Fbodyjunkie06's Avatar
The LPE GT11 cam comes to mind off the bat. 215/231 .631/.644 118.0 LSA, make sure you check PTV clearance will lift that high, but it is a great F/I cam. Also the LPE GT2-3 is a little milder at 207/220 .571/.578 118.5 LSA. You could definitely run the GT2-3 without worrying about PTV. The LPE GT2-3 I'd be willing to bet would work with your current stall perfectly, but the GT11 will lope harder having longer exhaust duration. Both great cams for superchaged apps, and I think the GT2-3 was designed for supercharged motors. Then you also have the GT9 at 215/247 .629/.656 121 LSA, or the stock ZR1 cam would work well. It specs at 211/230 .558/.552 122.5 CL. IMO all these cams would work well, but the GT11 would definitely need fly cutting or detailed PTV clearance checking.
Old Nov 26, 2010 | 05:09 PM
Sweet! Thanks for the helpful info. I've looked at the GT2-3 and it's pretty sweet and it's got a little lope at idle from what I've seen on YouTube. I've got my own HPTuners that I've done alot of tunes with, and with a little VE chessworking it should lope even harder, but with a stock Converter. Just wanted to see if I was going in the right direction.Thanks again!
Old Nov 26, 2010 | 05:44 PM
Jenson's Avatar
You can make any cam lope with tuning. PTV should be plenty fine with a 215/231, especially on 118. Max lift is achieved when the piston is farthest from the valves.
