Warhawk Solid lift springs???
Old Dec 1, 2010 | 03:21 PM
bluehawk2's Avatar
Default Warhawk Solid lift springs???
I have a set of Warhawk heads with spring s for a solid lift setup. They are the springs that came from world on the heads origionally.
Who makes those springs and where could I find out how much they cost?
I am going to run a hyd setup and I am wondering if the springs will be too much for a hyd lifter.
spring specs
1.550 diameter 200lbs@1.9" 480lbs@1.2" coil bind 1.150 max lift .700"
thanks
