Need help with ls2 pistons.
Old Dec 6, 2010 | 09:57 PM
LTX355's Avatar
Default Need help with ls2 pistons.
http://www.performancetrucks.net/for...d.php?t=473428
Old Dec 7, 2010 | 07:06 PM
LTX355's Avatar
part number zh1129-75mm shows to wrk with vin code N which was a floating pin application... looks like even sealed power dont know what there stuff fits... called them yesterday.
Old Dec 9, 2010 | 11:37 PM
LTX355's Avatar
Since no one builds budget stuff anymore and i have limited money... For all of you that read this if your looking for a piston that works with the ls2 floating rod on a 6.0 with stock crank... part number h1129ct works standard bore, 50mm(4.020), 75mm(4.03) and 100mm(4.04) are all available through summit racing at 29 or so a pop... these are flat top sealed power Hypereutectic pistons with coated skirts...
