Cam Question (variable Timing)
Old Dec 7, 2010 | 12:59 AM
jalper's Avatar
Restricted User
Default Cam Question (variable Timing)
I just purchased a ly6 and is swapping this out from my lt1, the motor is a 2009 and has variable timing, I plan on putting this in a sand car and my EFI will not support the variable timing (electromotive system)
What do I have to do to swap out the variable timing when i switch the cam?
do i need a new timing cover? what style chain, is the oil pump the same?
I do not know much about the ls style motors any help will be appreciated.
Old Dec 7, 2010 | 09:57 AM
Patrick G's Avatar
LS1 Tech Administrator
You should really consider getting an E38 processor like the one that came with your LY6. Then you could retain the cam phasing that your LY6 motor cam with.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 7, 2010 | 10:37 PM
jalper's Avatar
Restricted User
I think it would be to much work, my whole car is intergrated into the ecm, from the dash to the Vox headsets and the car to car unit, i would have to pretty much re-wire the rail from tim to tail.
from what i read, dont I just have to change the cam, witch needs to go anyway, and the timing chain set, with also replacing the cover, my pcm is a waisted spark, so i am not real concerned about the cam sensor.
is there anything i am missing?
