404 valvetrain with Warhawk 025250-3 Help
Old Dec 7, 2010 | 10:56 PM
bluehawk2's Avatar
Default 404 valvetrain with Warhawk 025250-3 Help
I have a 404 shortblock and i purchased a set of Warhawk heads(025250-3) to use on this engine.
These heads are listed for solid roller setups. I am going to run hyd.
I know the springs are not correct for hyd.
I think these heads came with manley severe duty valves. If that is the case then what valve springs do i need to put back on these heads for use with hyd lifters and using the heavy valves?
This is going to be used on a twin turbo setup, so is there any need in changing to different valves? Maybe to inconel or something lighter?
thanks for any help
Old Dec 7, 2010 | 11:09 PM
Whistler's Avatar
Sawzall and Welder Mod
The valves will be fine.. You should try and find out the specs on the springs before deciding to use them or not.
Old Dec 7, 2010 | 11:55 PM
bluehawk2's Avatar
1.550" dual springs
Spring Specs: 1.550": 200 lbs. @ 1.900", 480 lbs. @ 1.200", coil bind @ 1.150", max lift @ .700"
