headers for l92 ????
Old Dec 11, 2010 | 06:20 PM
djloc79's Avatar
Default headers for l92 ????
I am doing a v6 to l92 swap, and not sure what headers or manifolds to use. will the ls1 manifold match up or should i be looking for an aftermarket header setup? Or better yet, has anyone ran this setup with the stock truck manifolds? i figure that would require some cutting and welding.
Any help would be appreciated. I've learned alot since i started this project, but i still have alot to go.
Old Dec 11, 2010 | 06:45 PM
djloc79's Avatar
Ok... I know someone knows the answer to this question. What's the deal? Please help!!!!!!
Old Dec 11, 2010 | 06:52 PM
redbird555's Avatar
Its only been 20 min between posts u need to give people time to answer or else they may not if you keep bumping the thread. but anyway yes any ls1 header or manifold will bolt up they all use the same pattern
Old Dec 11, 2010 | 08:04 PM
djloc79's Avatar
Sorry, just frustrated. Thanx for the help.
Old Dec 11, 2010 | 08:06 PM
djloc79's Avatar
So, the stock truck manifold, is that out of the question? The motor came out of an 07 escalade.
Old Dec 11, 2010 | 08:15 PM
redbird555's Avatar
I dont believe the truck manifolds will fit you can use either the ls1 stock manifolds, or get a cheap set of ebay stainless longtubes for $150 then get a y pipe. are u keeping the vvt in the l92
Old Dec 11, 2010 | 08:26 PM
djloc79's Avatar
I don't think so. I'm going the route with the lingenfelter converter.
