l92 stroker build opinions needed
Old Dec 13, 2010 | 02:39 AM
topspeed7's Avatar
Default l92 stroker build opinions needed
trying to build my l92 for my f body, i want to go all motor so i want to stroke the motor. what is the best crank stroke 4.0 or 4.1? i dont want to deal with noise like the other guy here that sounds like a diesel.
Old Dec 13, 2010 | 04:35 AM
e-racer-ls-1's Avatar
Default Stroke
Most build 4" strokes.Any longer puts the piston skirt out of the bottom of the bore making it tough to survive.I am sure I will get blasted by guys running the longer stroke, but for 9 more C.I its not needed.Just my 2 cents.Good luck with your build.
Old Dec 13, 2010 | 08:18 AM
87silverbullet's Avatar
^^^^ I am with him. i am building a 418 l92 motor and I am going with a 4 inch stroke because I was worried about piston rocking in the bore at bdc. Plus I plan on hitting it with a 300 shot so I needed a better compression height and didn't want any crank deflection.
Old Dec 13, 2010 | 10:15 PM
topspeed7's Avatar
sounds like what i would want to hear, i was worried about the piston coming out the bottom more than what its safe, 418 sound like a plan afterall. Another question is how are people running ls1 heads on ls3 blocks if the rockers are offset?
Old Dec 13, 2010 | 10:28 PM
Pwebbz28's Avatar
The rockers are only offset because the valves in the head are moved over compared to a cathedral head.
Old Dec 13, 2010 | 11:02 PM
topspeed7's Avatar
duh, i see it now its offset at the tip of the valve not the pushrod... sorry for not looking first.
