Best heads and cam setup
Old Dec 23, 2010 | 09:55 AM
GuatoLT1's Avatar
Default Best heads and cam setup
I got a 2006 GTO m6. basic mods CAI and straight pipes after cats. I've been looking around and havent really found a cam and heads setup that a company sells. The car is only drove on the weekends and not planning on taking to the track until i fix wheel hop issues with new suspension. Also im putting long tubes on in the next few weeks. If anyone can lead me in the right direction i would appreciate it.
Old Dec 23, 2010 | 09:59 AM
82cetuner's Avatar
if your going to keep stock cubes i would recommend a set of stage 2 ls6 heads from texas speed and performance and have Patric G custom spec you a cam, but if you rather go with a off the shelf grind something like at torquer v2 would be good for you
Old Dec 23, 2010 | 10:19 AM
Tireburnin's Avatar
There are many many GTO's making great power with an Advanced Induction heads/cam setup. Search on this form and your GTO forum and you will quickly find that the results speak for themselves.
