l92 Valve Spring question/help
Old Jan 1, 2011 | 07:27 PM
Quick99TransAm's Avatar
Default l92 Valve Spring question/help
Using some l92 heads on my 6.0 build gonna be using a cam somewhere around 590-600 lift and i am looking for valve springs.I am using stock l92 valves this is a very mild build.
Old Jan 2, 2011 | 03:59 AM
67RSCamaroVette's Avatar
Patriot Dual Gold springs are what I use on all my builds. Inexpensive, strong, and reliable. I'd reccomend some comp beehives, but those big L92 valves are heavy.
Old Jan 2, 2011 | 06:14 AM
WKMCD's Avatar
PAC 1521's
Old Jan 2, 2011 | 11:45 AM
396D1SS's Avatar
im using texas-speeds prc .675 springs with no issues
Old Jan 2, 2011 | 04:35 PM
wickedbluess's Avatar
i ran prc dual springs with my 243s with no issue and going with prc dual springs for my l92s
Old Jan 2, 2011 | 06:50 PM
3pedals's Avatar
I have the patriot extreme duals now, they have been fine, but only have about 40 passes, and maybe 200 street miles on them. I will be stepping up to PAC duals with a new more aggressive cam in the spring.
Old Jan 3, 2011 | 09:45 AM
cam's Avatar
cam
I've run the Patriot Golds and loved them although they did fade out after a couple of seasons and maybe 10k miles street/strip 7K RPM at least once or thrice per day
Im running the PAC 1518's now on a mild 6.2 set up but from everything Ive read the 1521's are an excellent spring
