LS7 to a Automatic recomendations?
Old Jan 3, 2011 | 10:28 AM
The Big Al's Avatar
Default LS7 to a Automatic recomendations?
Will be installing a LS7 w/ automatic
Will be 4 speed auto (6 speed not a option)
Looking at 19154550
SuperMatic 4L85-E 4-Speed Transmission
Recommendations or know problems.
Know about the controller, not a issue
Thanks
Al
Old Jan 3, 2011 | 12:31 PM
FU2's Avatar
FU2
These guy's have done many Ls7 automatic conversions. There are a few others also.
http://www.rpmtransmissions.com/
Good luck.
Old Jan 3, 2011 | 01:41 PM
67RSCamaroVette's Avatar
Theres nothing special to bolting an auto to the LS7.. just make sure you get the correct flexplate for your application.
Old Jan 5, 2011 | 09:26 AM
rsz288's Avatar
Ditto ^^^.
Old Jan 5, 2011 | 09:53 PM
twinturbo496's Avatar
Much better ratios than a 4L60E
Much stronger than a 4L60E
Very strong upgrade parts available if you need them later.
Many parts interchange with TH400.
Not really much bigger than a 4L60E.
I have one behind my 496 with a 14-71. It has a DIY Rebuild and a FMVB conversion (no electronics) and the only problem is a slow 2-3 shift, that is a known problem with the FMVB kit that I used, and not a problem with electronic units.
The 4L80E is a very good transmission.
Don't be afraid to cut off the wings, they serve no purpose.
Old Jan 6, 2011 | 04:19 PM
IDRIVEAG8GT's Avatar
This sucks that the 6L series is not an option I don't think they're as strong as a 4L but those other two gears are nice to have.
