COMP Cams Hi-Tech Oil Restricting Pushrod
I did my pushrod check and need to order new pushrods.
Has anyone used the COMP Cams Hi-Tech Oil Restricting Pushrods.
I understand it helps keep the oil flow to the bearings and less to the top of the head.
I am also installing a ARE three stage dry sump system.
COMP Cams Hi-Tech Oil Restricting Pushrods were built for a reason.
Will I get enough oil to the rocker arms and valve springs. I need to know before I make my order for new pushrods.
gary@grbowler.com
With your ARE dry sump system you should already be set anyway and you can keep your rockers and springs happy by not restricting the pushrods.
Thanks for your answer
