Reluctor wheel?
Old Jan 28, 2011 | 09:03 PM
silverta00's Avatar
Default Reluctor wheel?
Will a stock ls reluctor wheel fit on a sonny bryant crank, or do you need to use a crank trigger?
If you run a crank trigger what all do you need to change to run it?
Old Jan 31, 2011 | 10:41 AM
Callies Performance's Avatar
A reluctor should be included, when you purchase an after-market crank. Stock wheels will work, but chances are you bend them when removing it.
Old Jan 31, 2011 | 11:23 AM
racer7088's Avatar
If the crank was originally ordered to run BS3 or something with a crank trigger it was probably sent with no reluctor as I do at times and with Callies too on pure race stuff. But like Adam is saying, Sonny Bryant still probably left the provision to mount the reluctor which would or should fit the oem reluctors if you need to put one back on.
The last two Sonny Bryants we ordered and received had no reluctors since we ordered them that way but we put a reluctor back on one later since the guy wanted to use it in a stock computer app. It still fit right back on very nice.
