cam help
Old Feb 10, 2011 | 03:03 PM
earmuffs's Avatar
Default cam help
Intake Duration at 050 inch Lift 228
Exhaust Duration at 050 inch Lift 232
Duration at 050 inch Lift 228 int./232 exh.
Advertised Intake Duration 290
Advertised Exhaust Duration 294
Advertised Duration 290 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.600 in
want to run this cam on a 408 with 243 heads, stock rockers, comp 918 springs, 11.5:1 compression. what do you guys think?
Old Feb 10, 2011 | 05:59 PM
Ragtop 99's Avatar
You need the LSA and ICL for us to understand the valve events. Overall looks like it will be pretty tame in a 408.
Lobes seem slow for a 600 lift cam.
Old Feb 10, 2011 | 07:32 PM
earmuffs's Avatar
lsa is 112 sorry.
Old Feb 11, 2011 | 06:08 PM
Ragtop 99's Avatar
on the smallish side, but low end should be very strong. I would not want any advance ground in.
Old Feb 12, 2011 | 03:11 AM
earmuffs's Avatar
thank you guys for your input. when you say tame and smallish. what would you recommend as a bigger cam but still streetable
