Are these Ls3 intake valves?
Old Feb 26, 2011 | 04:50 PM
tiresmokinV8's Avatar
Default Are these Ls3 intake valves?
Or did I get sent the wrong ones. I ordered 2 ls3 intake valve from Scoggin Dickey and they came today, The box says #12569427. I bought the other 6 used off a member here who pulled them off a set of ls3 heads he had where the piston hit the head and messed 2 of the valves up.
New ones from sd
Used from here
And the L92's that I pulled
Shouldnt they look like the one on the right in this pic? Machined surfaces.
I dont have a scale to weigh them or I would have.
Old Feb 28, 2011 | 06:12 AM
I weighed the new ones and a used one that I bought off the member here and they came out to 108-109 grams. Definately got sent the wrong ones several times.
Old Feb 28, 2011 | 07:23 AM
Hans Grüber's Avatar
The two new ones are definitely not the hollow stem LS3 but the L92 valves.
Old Feb 28, 2011 | 07:55 AM
Yes Ive figured that out. Its strange that the 6 used ones I got turned out to be L92s and so were the 2 brand new from Scoggin Dickey. Doesnt anyone know what a LS3 hollow stem valve is? I have the part number correct and it even said Ls3 on the boxes the 2 new ones came in.
Old Feb 28, 2011 | 04:29 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
We found a few more misboxed from GM when we went to get your replacements (we checked them all to be sure you got the right ones this time).
Regardless, we found you the correct valves and they are on their way to you!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Feb 28, 2011 | 04:31 PM
Thanks, I figured it was just a freak mix-up or something. Engine will be on the stand for a few more months so no harm no foul. Thanks for the prompt fix though!
Old Mar 2, 2011 | 03:37 PM
briancb1's Avatar
LS3 valves have all surfaces machined.
