Lsx swap problems.. Cam position and tach..
Old Feb 26, 2011 | 08:11 PM
bandit383's Avatar
Default Lsx swap problems.. Cam position and tach..
All right guys I’ve got a LSX tall deck in a 2001 trans am with LS2 conversion kit. the cars kicks out DTC P0343. I have Ohms CK the harness from extension harness to PCM all good. The ignition wire to sensor has 12v with the key on. Now when the cars runs the hi and lo don’t record any values on HPtunners. I am at a loss as to what is wrong... Also the tach in the car is inop but will read through the PCM.. Does anyone have the correct pin out for the cam sensor I.E pin x from PCM to pin y on sensor.
Old Feb 26, 2011 | 11:49 PM
Brian Tooley Racing's Avatar
I had to swap the "A" and "C" wires when I did my Gen III to Gen IV swap.
Old Feb 27, 2011 | 12:21 AM
bandit383's Avatar
I saw a post or two with that fix... Will try in the A.M.
Old Feb 27, 2011 | 09:02 AM
spaz1's Avatar
I had the same problem with mine. I got the harness from Texas speed. Swaped the wires and worked mint.
Old Feb 27, 2011 | 05:39 PM
bandit383's Avatar
Swapped wires ops ck good..
