Oil Catch Can
Old Feb 27, 2011 | 11:10 AM
SHORTZ A KILLA's Avatar
Default Oil Catch Can
function? necessity? I'm having an LS3 418 Stroker built by Xtreme HP Solutions -should I invest in one? I'm kinda fuzzy on its function and want to make sure I'm not wasting $$ since the LS3 is not an LS1 which I know there were issues that the can was needed.
Thank you in advance
http://cgi.ebay.com/ebaymotors/JDM-7...item230e78a04f
Old Feb 27, 2011 | 12:20 PM
2010ss1's Avatar
catch cans are good and functional but that ebay piece looks like a joke, I'm sure you can find a bettter one or make your own using an oil seperator.. very common part for compressors or jegs has one that looks better than that.
But if your venting to atmoshpere then you dont need one. It all depends on what your doing with your pcv system
Old Feb 28, 2011 | 01:33 PM
what about using a crankcase breather on the valve cover. Is that alternate option? Thanks
Old Feb 28, 2011 | 03:20 PM
t/a98's Avatar
My spelling is way off, but the dual can saiko michi one is the only good one... Idk it's some Japanese name like that... Anyway it will catch alot the others not so much... I don't have one, I want one though, more of a money thing than anything else
Old Feb 28, 2011 | 06:49 PM
yeah I called the builder he has one for me that doesn't require alot of fabrication to make it fit/work-thanks
Old Mar 6, 2011 | 02:32 AM
Johnny-LT1-runner's Avatar
Rockstar
If you're building an LS3 you should have the LS3 valley cover, that has a system built in that functions the same as a catch can.
Old Mar 11, 2011 | 07:34 PM
gtomama's Avatar
I'm using PCV delete...
Old Mar 12, 2011 | 02:06 PM
Jimbo1367's Avatar
What is it then? I thought the LS3 valley cover just has a port for PVC.
Old Mar 13, 2011 | 03:26 AM
DietCoke's Avatar
Except it doesn't, and generally sucks at controlling oil vapor period. I go though a qt/600 miles with my car Would certainly rather that quart end up in the can then in the intake/burned off.
Old Mar 13, 2011 | 09:47 PM
396D1SS's Avatar
I run a catch can on my ls3 and it works. I would recommend it
Old Mar 15, 2011 | 02:05 AM
MotoFreak's Avatar
pricey pricey pricey
Old Mar 15, 2011 | 02:37 AM
Rockstar
I see no reason why it shouldn't work like it is designed. I'd say you have other problems if you're burning that much oil...
