Will stock head gaskets be fine on my ls2?
Old Mar 1, 2011 | 05:47 PM
firehawk68mcleod's Avatar
Default Will stock head gaskets be fine on my ls2?
Im doing a ls2 build... wiseco -11cc pistons, ported 317s, stock stroke, and a d1 procharger with 3.4 pulley... Im just wondering if gm multi layer gaskets with be fine replacement, and will hold up? I can get gm ls2 gaskets at a resonable price vs aftermarket ones. thanks let me know?
Old Mar 2, 2011 | 03:52 PM
any opinions thanks
Old Mar 2, 2011 | 08:40 PM
BBC632Camaro's Avatar
How many lbs of boost are you running? The GM Multi layer steel gaskets will be fine unless your running a crazy amount of boost. More importantly make sure you decks are perfect. Any warpage creates a problem some head gaskets can't fix.
Old Mar 2, 2011 | 08:47 PM
Im having the block deck to make sure the surface is flat and the heads as well... i think the boost will be 15-18
