Building a big inch LS2. Need some help...
Old Mar 3, 2011 | 04:59 PM
Danny's Avatar
Default Building a big inch LS2. Need some help...
Hey guys,
I just bought a used LS2 block and I want to use it for a special project I have coming up. I’m looking into building a big inch motor that can withstand boost (15-18PSI), if I decide to throw that into the mix later. But for now it will just be an N/A motor with maybe a 250shot. I wanted to know how big can these blocks be bored out to (safely) when they’re re-sleeved. I was looking into Darton dry sleeves as a replacement for the sleeves. I was thinking of building at least a 440cu or 454cu with a 4.185” bore. Obviously the 440 would require a 4.000” crank and the 454 would require a 4.125” crank.
So here are my questions...
1). Would a 4.185” bore be too big for reliability (say for 15-18PSI of boost)?
1). If I decide to build the 454cu would the 4.125” crank require any modification to the block (maybe some clearance issues)?
This isn’t an “all out” build, just a strong street strip combination. I know a N/A and a boost engines are build differently sometimes (different pistons, rods, etc) but I just want to know if using this size bore and stroke is reliable. If I wanted to add boost in the future I want to be able to know that I can just swap the pistons and be done with the bottom-end.
Thanks in advance guys
Old Mar 3, 2011 | 09:22 PM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default LS2 dry sleeve
The Darton dry liners will go to 4.185" bore but naturally aspirated only. I would keep the bore size at 4.155" for any nitrous or boosted application to keep a bit more real estate for the head gasket to seal on.
Cometic makes a Phuzion head gasket in 4.180" bore only as I recall. That will work fine on a 4.155" bore.
When I install these sleeves, I cut rod clearance notches in the bottom end included in the pricing. The notches are deep enough to clear a 4.25" stroke with most rods.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Mar 4, 2011 | 03:39 PM
Danny's Avatar
Steve,
Thanks for your reply. Ya, that's what I figured but I wanted to get a second opinion? The last thing I want to do is go to thin on the sleeves and end up regreting it later.
I'll just go with a 4.150". With a 4.125" crank that'll still give me 446ci which is plenty of torque for the weight of the car.
How much do you charge to resleeve a block like this if I were to take you the sleeves? I think my buddy can get them for me at cost but I just need to have it resleeved and bored to spec.
Thanks again Steve.
Old Mar 4, 2011 | 03:47 PM
Shawn @ VA Speed's Avatar
Originally Posted by Danny
Steve,
Thanks again Steve.
you need to stay at a max of 4'' stroke for n2o or boost. this will keep a decent piston in the thing
Old Mar 4, 2011 | 05:36 PM
1toofastlt1's Avatar
I hear that with a 440 ls2 long sleeve with a 6.25 rod will have problems with burning oil. Is this true that the oil rings wont seal good due to the placement of them over the wist pin????
Old Mar 5, 2011 | 04:56 PM
Danny's Avatar
Guess I'll stick to the 433 I first had in mind.
Thanks for the reply guys.
