Oil on spark plugs....
I was giving my buddy a hand this wknd to help him figure out why he's getting misfile codes. I pulled the plugs on his heads/cam LS2 and found that the plugs from #1 & #4 cylinders were covered in oil and carbon. #4 was the worse. Those plugs have only been on there for about 1k miles. The engine runs fine but he's just getting misfire codes.
I'm thinking that maybe the oil control rings are bad or there might be some bad valve guides. Before I tear everything apart I wanted to get a few opinions first.
I was thinking of performing a leak-down test first to eleminate the possibility of bad rings. Then if that turns out ok I was thinking of then removing the heads for inspection.
What do you guys think?
Thanks in advance.
First I'll check the compression just to eliminate the rings from being bad. I doubt the rings are bad. This motor has only seen nitrous a few times and that was it. It never even made a complete pass on nitrous.
I finally had time to run a leak-down test on my buddies LS2. All cylinders are 7-14% compression loss which is acceptable. We'll be pulling the heads off this week to check the valve guides.
