E-rod engine help
We're hoping to use a E-rod engine in a few different projects and its has the harness ready to run witch will make life easy to set up.
We're making 2 identical jetboats and a custom car similar to an ultima gtr. (total or 3 engines)
So help make sure its all going to work we're trying to locate a dealer to help us with a cad file or drawing/photo's with dimensions. or an contact email for gm performance parts.
We thought the e-rod engine files and dimensions would be common somewhere as the clearly want hotrod builders and custom car builders to use them.
Cheers brad
