Which block for 4.185 bore
Old Apr 19, 2011 | 03:14 PM
LS6's Avatar
LS6
Intresting Thread
Old Apr 21, 2011 | 02:46 AM
youngb's Avatar
racer7088, what would be the maximum stroke allowable in your mind for N2O on an LSX block and an ls3 with Darton sleeves? I'm on the verge of making the leap but want to make sure I'm going in the right direction. Thanks
Old Apr 21, 2011 | 11:02 AM
Whistler's Avatar
Sawzall and Welder Mod
How much N2O?
Old Apr 21, 2011 | 11:11 AM
youngb's Avatar
A 200 shot should do the trick.
Old Apr 22, 2011 | 01:50 AM
racer7088's Avatar
Probably 4" in the LSX and MID with normal pistons. Maybe with a custom piston and shorter rod you could do a 4.125 in the MID with the longer sleeve.
Old Apr 22, 2011 | 09:13 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We have the Comp Cams block & a resleeved LS3 block in stock that can get you where you need to be.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 22, 2011 | 10:33 AM
youngb's Avatar
Thanks. That's good info.
Old Apr 22, 2011 | 10:36 AM
youngb's Avatar
Jason, I didn't see any info on either of those blocks on your website. I was interested in prices and specs. Thanks
