05 gto l92 swap
Old Apr 3, 2011 | 05:56 PM
charlesready's Avatar
Default 05 gto l92 swap
Sounds like a lifter tap. I checked the rocker twice. I did a cam and head swap. Gets louder at warm up. I already checked the exhaust for leaks. What about the cam plate o ring?
Old Apr 3, 2011 | 06:39 PM
180ls1's Avatar
hows the oil pressure? did you swap cams also?
Old Apr 3, 2011 | 10:46 PM
Yes I don't have a oil pressure gauge on it. Took it apart tonight going to cam the cam plate seal. The plate had some wear on the gear side, is that normal?
By Brett Foote | 2026-06-04 05:00:17
