CAM CHOICE - The "WRONG" Question - EXPERTS Needed !
Old Apr 21, 2011 | 09:24 AM
ez2cdave's Avatar
Originally Posted by 87silverbullet
Get in touch with WKMCD on here. He has a 427 with rect port heads and Shawn at Virginia speed pretty much spec'd everything and the timing is very conservative and the cam is nothing compared to what everybody would think.
Thanks . . . I'll look him up !
Dave
Old Apr 21, 2011 | 10:17 AM
Patrick G's Avatar
LS1 Tech Administrator
Originally Posted by ez2cdave
Wow - great information guys!
Is it "better" to run less spark advance and higher compression or more spark advance and lower compression ?
Is there a "standard" or "rule of thumb" for spark advance vs CR ?
What is considered "full timing" in a N/A Street motor without power adders ?
Dave
An engine will typically make maximum cylinder pressure at 13 degrees ATDC. To make maximum torque, you want your ignition timing to occur early enough to allow this peak cylinder pressure to occur at 13 degrees. The amount of advance depends on cylinder head port/chamber design/fuel choice and cam timing events. Some combos need more advance, some need less. If your static compression is so high that you can't run enough advance to allow peak cylinder pressure at 13 ATDC, then you will lose power.
Here's an example:
Say you have a very efficient set of heads like a 65cc Trick Flow 215 on a 346 making 10.5:1 SCR running 91 octane. This head likes a 40 degree burn from ignition advance to peak cylinder pressure so that means 27 degrees BTDC ignition advance + the 13 ATDC to achieve peak cylinder pressure.
Now you raise the static compression to 11.5:1 and can only run 23 degrees of ignition advance before you detonate. That means you will be making peak cylinder pressure at 17 degrees ATDC. 4 degrees past ideal. So basically, you will make less power with more compression and less timing in this case.
As a general rule, you will make best power with the static compression and fuel that allows you to make peak cylinder pressure at 13 degrees ATDC.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 21, 2011 | 01:31 PM
ez2cdave's Avatar
Here's an example:
Patrick,
Thanks for the great information . . . I am learning a lot here, but this is a much more complicated process than I had imagined !
How does one know how much timing various heads "like" ?
Is there a reference source or is it all just based on personal experience ?
I want to be sure of choosing the right heads and CR . . .
Dave
Old Apr 21, 2011 | 01:46 PM
SSCamaro99_3's Avatar
Now you raise the static compression to 11.5:1 and can only run 23 degrees of ignition advance before you detonate. That means you will be making peak cylinder pressure at 9 degrees ATDC. Remember, the closer you are to TDC, the more vertical your rod will be, and the less leverage it will have on the crank. Like pushing on a bicycle pedal with it almost at the top. So basically, you will make less power with more compression, but less timing in this case.
Wouldn't you be at 17 degress ATDC? Just want to make sure I am following correctly.
27-40= -13
23-40= -17
Old Apr 21, 2011 | 02:23 PM
Patrick G's Avatar
27-40= -13
23-40= -17
Yes, sorry, brain fart. With 23 degrees of ignition advance, the burn would occur 4 degrees past the ideal point of 13 degrees. I'm so used to explaining why nitrous needs its timing retarded (because of a much faster burn), that I got my math transposed. I will correct my previous statement in case anyone else quotes it in error.
__________________
Old Apr 21, 2011 | 02:36 PM
ez2cdave's Avatar
Patrick,
Please don't confuse me any more than I already am . . . LOL !
I want to be sure to be able to make the right choices !
Dave
Old Apr 21, 2011 | 04:59 PM
KCS's Avatar
KCS
Moderator
Patrick,
Dave
I was given a good analogy once in regards to combustion; think of it as a forest fire. The trees represent the oxygen in the atmosphere and the dirt and sand represent the other elements which don't really aid in combustion. The more densely packed the trees (or oxygen molecules) are, the faster the forest fire can spread. Back to the combustion chamber, if you have more oxygen packed into the cylinder, the flame can travel across the cylinder and build pressure quicker.
Conversely, a wildfire won't spread very quickly in a barren desert, so an engine with poor VE may require more spark advance in order to build maximum pressure at that sweet spot Patrick spoke about.
Old Apr 21, 2011 | 06:13 PM
ez2cdave's Avatar
Guys,
Could anyone please take a look at these specs and see if I have any "conflicts" . . . Do I have the potential of "too much flow" for a "STREET" 427 ?
Please feel to make suggestions for any changes and why they would be needed . . .
The car would be 99% street daily-driven, and I do mean "daily-driven", just like a stock family car would be . . . Traffic, Stop & Go, Freeway, etc.
SPECS :
427cid / 7.0L
LS2 Block - DARTON Dry Sleeves - 4.125" Bore
COMETIC "PHUZION" Gaskets - 051" Compressed Height
WISECO "LS Series" Pistons #K395X130 - 10.9:1 CR (Not 100% chosen-More CR Info Please ?)
F.A.S.T. - LSXr 102mm Intake - Unported
102mm Throttle Body
KOOKS Long-Tube Headers ( 1.875" - 2.00" Primaries / 3.5" Collector, Dual High-Flow Cats, Full 3" Magnaflow Cat-Back Exhaust System
CAMSHAFT : Will Be A CUSTOM Hydraulic-Roller . . . Specs to be determined !!!
West Coast Cylinder Heads - CNC Stage 2 L92/LS3 Heads ( Flow Numbers Below )
INTAKE - 2.160" Valve / EXHAUST 1.600" Valve / 28" of H20 w. a 4.155" Test Bore
LIFT 0.100 0.200 0.300 0 .400 0.500 0.600 0.650 0.700
INT _75.4 _160.0 _226.6 _280.4 _323.0 _353.7 _360.6 _367.6
EXH _57.4 _117.6 _182.4 _222.5 _240.1 _249.0 _251.4 _254.3
http://www.proheads.com/WCCH%20L92.html
Weight - Approx. 3850lb w/Driver
4L80E Transmission - 2.48 1st Gear, 1.48 2nd Gear, 1.00 3rd Gear, .75 4th Gear
YANK 3400 RPM Lock-Up Converter
3.54 Ring & Pinion ( Strange S60 Dana rear )
THANKS !
Dave
Old Apr 22, 2011 | 09:06 AM
Patrick G's Avatar
If you don't have the heads yet, I think you'd go a lot faster with either some WCCH LS7 heads or some MAST LS7 heads with cathedral ports. While the L92 heads are good, they're not great compared to the LS7 and MAST stuff.
__________________
Old Apr 22, 2011 | 01:37 PM
ez2cdave's Avatar
Hi, Patrick,
I am concerned with the motor getting "lazy / flat / boggy" at low RPM's, since it will be 99% street driven. I am looking for a big-cube motor that has a smooth idle, does not surge or overheat, gets decent MPG, and is a "very nasty surprise" at a stoplight. It would have to "behave" in daily stop & go driving, idle for extended periods in rush-hour traffic, and Pass NC OBD-II Emissions . . . It would be driven just like a "family car", but with a set of "brass *****" !
As it stands, I am concerned about the WCCH LS3 Stage 2 heads being too large for my application.
Since the other heads are even more "aggressive", wouldn't that make things worse for me ?
I haven't chosen a CR yet, but I want to be able to run full timing ( any thoughts on CR with my combo ? ) . . . 91 Octane pump gas . . . No power adders.
Patrick, I am going to have you spec out the cam, once the components are all finalized .
Please forgive the "dumb questions" . . . I am almost 50 and my last "real car" was a 1970 454 Chevelle, almost 25 years ago . . . Being "married" can do things like that to a man, but my wife is a lot more "tolerant" now . . . LOL !
Thanks to you, and everyone else, for your patience and very helpful information !
Dave
Old Apr 24, 2011 | 01:20 PM
WKMCD's Avatar
Not an expert but...
I would go straight to the Stage 3 WCCH L92's. Richard has them flowing right with LS7 heads. Run as much compression as you can and still get 28-29 degrees of timing. That seems to be about 11.3 11.4:1 The sweet spot on the intake side of the cam seems to be 230-234 and 8-10 degrees of split. The heads like lift so .640 or better is good.
Just my $.02
Good luck!
Kevin
Old Apr 24, 2011 | 02:34 PM
  #32
ez2cdave's Avatar
Just my $.02
Good luck!
Kevin
Kevin,
Thanks for your input on my combination . . .
I need and welcome all the help I can get !
Dave
Old Aug 21, 2011 | 12:35 PM
  #33
TwoValveKid's Avatar
Ended up doing something similar. Picked out pretty much the entire drivetrain and did cam/pushrods last. LS3 stroker from Scoggin Dickey with Mast Medium bore LS3s and a patrick G spec'd cam. What really sold me on the Mast stuff is that they outflow just about every ported LS3 on the market...with a much smaller runner.
Old Aug 21, 2011 | 12:47 PM
  #34
87silverbullet's Avatar
That usually happens when you have an aftermarket casting. They were able to tweak the port the way they wanted to.
Old Aug 21, 2011 | 03:21 PM
  #35
Yep. But still. I was really waiting for the TSP Small Bore LS7's but parts started showing up and i got a nice deal on a set of Mast Medium Bores through Scoggin Dickey. Even got harland sharp to supply some rockers.
