pushrod length: unusual
Old Apr 20, 2011 | 12:21 AM
serpentnoir's Avatar
Default pushrod length: unusual
I noticed most people go with 7.3~7.4" pushrods with performance cams. I measured mine and to achieve .08~.1" preload I need a 7.525" pushrod. The block was milled .015 and the heads .005. I have Yella Terra rockers that are shimmed .042. The cam is 232/240, .575/.585.
Considering the milling I find it strange that I need such a long pushrod. Could I be doing something wrong? I converted the lifters to solid and made sure the cup was in the same place.
Old Apr 20, 2011 | 09:17 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You verified the lifter was sitting on the base circle of the camshaft as well? What tool or method are you using to find that number?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 20, 2011 | 12:41 PM
I converted a lifter into a solid lifter by gutting it and milling a spacer to go inside under the cup.
I made sure the cup was in the same position relative to the lifter body.
I made an adjustable pushrod using an old 5/16 SBC pushrod that I threaded.
I installed everything on the base circle and adjusted the pushrod until I had zero lash.
I pulled the rockers and measured the pushrod. I measured 7.425". If I add 0.080" for preload I get 7.5".
Old Apr 20, 2011 | 01:16 PM
Remember, when you order a 7.400" 5/16"pushrod, tip to tip it will measure about 7.417" or so. That's gauge length. So take off the .017-.020" from your tip to tip length, and your zero lash will be right at 7.400" (round to nearest .025" which is the standard length increment). Then add your preload. From your measurement, I'd go 7.475" which will measure tip to tip about 7.495".
What heads are you running?
__________________
Old Apr 20, 2011 | 01:58 PM
You are right. all my measurements are with the oil hole.
Heads = L92 on LS2 block with Manley Race Master valves and PAC1518 springs set at 1.8" seat height. I didn't have to shim the seats which I found strange.
Maybe the valves are longer than stock causing the pushrod to be longer. I know that w/o the Yella Terra shims, the wear pattern on the valve tip is not good. So I had to raise the rocker slightly to get a narrow and centered pattern.
Old Apr 20, 2011 | 02:38 PM
Longer valves = shorter pushrod though.
__________________
Old Apr 20, 2011 | 03:00 PM
ducatisl's Avatar
Nice work serpentnoir.
Matt, thanks for the 0.017-0.020 info. I was wondering why some of my measurements weren't quite adding up and forgot about that
