Going from 2.02" to a 2.08" inlet valve worth it?
Old May 19, 2011 | 06:29 AM
lstvr's Avatar
Default Going from 2.02" to a 2.08" inlet valve worth it?
Hi Guys,
Dart 225's on my 416CI, they are lightly ported, and the bowls are properly blended, the combustion chambers are also opened out to unshroud the valves and drop the compression.
I am looking at having them professionally ported, while there is it worth going up on the valve?
Old May 19, 2011 | 09:24 AM
Stage7's Avatar
Did you mean "intake" valve?
Old May 19, 2011 | 09:28 AM
lstvr's Avatar
Yes, edited to correct!!
Old May 19, 2011 | 10:49 PM
ChucksZ06's Avatar
Yes it would be worthwhile if porter opens up the bowl area along with the larger valve.
