LS7 Block Dipstick Drill Jig question
Old May 23, 2011 | 09:14 PM
RGSS's Avatar
Default LS7 Block Dipstick Drill Jig question
I am converting my LT1 powered F Body to Gen IV Power. Thats right, I am installing a wet sump LS7 and need to drill the block for the Dipstick.
Where can i get the drill jig used to drill in the appropiate angle and what dipstick should I use?
Thanks for any advise.
Old May 23, 2011 | 10:15 PM
ChucksZ06's Avatar
I do not know about the jig...I drilled a pilot hole in mine and then finished it to the correct size. I reused the 02 corvette dipstick.
Old May 23, 2011 | 10:29 PM
Whistler's Avatar
Sawzall and Welder Mod
Drill the hole in the boss, then use the dipstick that matches your oil pan. You'll be fine without a jig, just mic the dipstick to figure out what size bit to use.
Put grease on the drill bit to catch drill shavings so that none find their way into the bottom end.
Old May 23, 2011 | 11:07 PM
RGSS's Avatar
Thanks for the replies guys i appreciate it. I did search a bit and found this photo published by HOT ROD where they mentioned the Jig availiable from TechAFX but the site does not seem to be working. I think I will go ahead and drill it then. I guess that by drilling at a right angle on the center of the boss surface I should be OK then
Old May 24, 2011 | 08:02 PM
Robofuzz's Avatar
I'm very interested in your build. What heads, cam, intake, etc. are you going with?
Old Jun 9, 2011 | 07:20 AM
RGSS's Avatar
Well I went for it without the drill jig, just drilling thru the center of the boss with the appropiate drill sizes and it came out real good:
Callies 4"stroke crank, compstar H beam rods, Mahle pistons, ARP, etc
