Is there a difference ?
Old May 30, 2011 | 03:54 PM
Doug G's Avatar
Default Is there a difference ?
Is there a difference in LS motors for cars Vs. boats ?
Old May 31, 2011 | 04:32 AM
Doug G's Avatar
Anyone ?
Old May 31, 2011 | 09:00 AM
allblowdup's Avatar
Yup. The marine engines are rated at less power. The ls3 marine power engine is rated I think at 410 hp while the crate ls3 fuely is 480 hp. couldn't tell you what the actual difference between the engines is though. Possibly camshaft.
Old May 31, 2011 | 10:15 AM
Stage7's Avatar
As a general rule, marine engines tend to be designed for extended high rpm operation vs. engines designed for cars.
Old May 31, 2011 | 04:12 PM
Doug G's Avatar
I was more worried about CCW or CW rotation, lower compression and such.
Found one or two on Ebay (new) but marine engines and wasn't sure what's what.
Old Jun 6, 2011 | 07:25 PM
flash911's Avatar
Marine engines are set up to run like an RV going uphill, mostly because they don't build momentum in the same way cars do. Typically this has to do with cams and Inconnel exhaust valves..
