Iron block
Old Jun 9, 2011 | 09:32 AM
ssdungeon's Avatar
Default Iron block
For those of you with iron blocks living in the southern climates avg 88-95 degrees. What is your average coolant temp. Mine is 235-245 would you say thats too hot on a long drive say an hr.?
Just seems high. Its been that way, no codes thrown good pressure good power just hotter than my Z was running with the same block almost same size cam just not stroked.
Old Jun 11, 2011 | 08:00 AM
BlueStreak362's Avatar
Drove my car home from work when it was 95 out(heat index of 104) and the temp never got over 210, i run water wetter and have my fans turned on sooner however.
Old Jun 11, 2011 | 09:43 AM
G Engines's Avatar
I have had a customer that had this same problem he needed a new water pump car runs cool as can be now.
