ls3 bottum end....to forge or not
Old Jul 1, 2011 | 09:54 PM
Floorman279's Avatar
Default ls3 bottum end....to forge or not
im thinking about buying an ls3 crate motor in the future....but also plan on throwin a big cam in with a fast, good heads, full exhaust, and some induction work....so imlooking at probly 610-675 hp flywheel.......if the motor is Brand new, is it worth putting some wiseco pistons in and change the rod boltS?
Old Jul 1, 2011 | 10:10 PM
matrixiskool's Avatar
Ls3's are at ~425 flywheel from the factory so youre looking to add another ~200 horsepower. Not a bad idea to put in wiseco pistons, but you'll need to do a fair amount of machine work. I would just buy a short or long block off Texas Speed. Their prices are fair and you can do more with your money than if you bought an Ls3 from GM as well as not having to tear apart a new motor.
Old Jul 2, 2011 | 05:03 PM
any other thoughts? id prefer just to get the gm crate motor.......how much are you guys running on your completely stock bottum end?
Old Jul 2, 2011 | 07:37 PM
litle88's Avatar
If there accessible, why not rods n pistons?
Arp main studs and head bolts.
You'll be good then.
Old Jul 2, 2011 | 10:20 PM
how good are the ls3 rods?
Old Jul 2, 2011 | 10:22 PM
COPO9560's Avatar
I don't understand why one would buy a crate engine, tear it apart and substitute a bunch of parts including the cam, pistons and heads. The LS3 has powder metal rods, why not upgrade these to forged too? Seems to make more sense to buy what you want from the start from a reputable builder and be done with it.
675 hp is a lot to ask from stock cubic inches. For this power level, a 427, N2O or FI would probably be a better choice.
Old Jul 2, 2011 | 10:31 PM
i kinda just wanted the benefit of the ls3 heads and intake........plus a forged ls3 from tsp ran about 8600 plus shipping 1500 miles....with justthe basic stuff i needed.......ls3 crate goes for 6500 pluys flat 125 shipping.........just seemed more budget friendly
Old Jul 2, 2011 | 10:34 PM
plus id need to use my shitty ls1 top end for a while.....meaningid have to shell out another 2000 for a fast 102/102 combo with injectors and rails.....if i got the ls3 i could get by alright with a stock unported ls3 for awhile......same with the heads.....thus saving me more money........
 Michael S. Palmer
Old Jul 3, 2011 | 10:26 AM
blky2k2z's Avatar
Your asking everyone a question than telling us what your gonna do its double ended..... The GM LS3 won't handle the horsepower you wanna make day after day flogging the hell out of it but your saying you wanna put it together then upgrade take apart put back together raw raw raw raw...for the money and hp you wanna make I would buy a tsp forged 408 a ported trickflow head or something like that and throw the bottle to it.. That setup should spank the **** out of a cammed stock bottom ended LS3 plus then you only do it 1 time
Old Jul 3, 2011 | 11:27 AM
im not planning on retaking it apart so i dont follow you there.i see what your saying but im trying to do thiss as budget friendly as possible.....kinda hard to explain.....but if i were to get the tsp, after getting all the forged stuff, id be running 8600 bucks...plus shipping to myhouse so im pushing 9000......then id have to buy a fast setup unless i really wanna choke the new motor by using my ls1 intake....so now im looking at at least another 700......so im close to 10000 there. my main point of this thread was just asking how much a new ls3 stock bottum end could handle......if it could handle 650-700hp, then i could just buy an ls3 crate, and do a cam swap for now.....very easy to do so not a big deal......plus 480-500 flywheel hp with a cam will get me by for now. so i wouldnt even have to touch the bottum end. then later down the road when i have more room in my budget, i can do heads and maybe a fast, but the ls3 is a very good intake as is. that would be running 6500, so shiipped to my door probly alittle under 7000......so id prefer todo the crate because id be saving 3000. am i wrong for thinking this way? i know you gotta pay to play but i only can afford about 8000 total for this and id really like this to go through. am i makingsense at all?
Old Jul 3, 2011 | 11:29 AM
396D1SS's Avatar
speaking from real world experience. 550rwhp on a stock bottom end ls3 wont be a problem.
Old Jul 3, 2011 | 11:46 AM
yea this will be my every mod here.......
long tubes with true duals
Lid and ftra
probly stock ls3 intake, may port eventually
ported ls3 heads
bpretty large cam
igger tb
all that i assume i should be seeign about 610-660 flywheel hp.....is that about right? so i dont think it should be necessary to forge......so thats all im trying to get out of this thread weather i need to forge or not
Old Jul 3, 2011 | 02:13 PM
If you're expecting 200 horsepower out of those mods then you'll be spending over 2 grand on heads alone. That added to the cost of a crate motor comes out to the same price as building your own forged 427. Just saying.
Old Jul 3, 2011 | 02:14 PM
litle88's Avatar
I think you'll be more at 550 ish flywheel anyways.
Old Jul 3, 2011 | 02:26 PM
396D1SS's Avatar
Lid and ftra
ported ls3 heads
bpretty large cam
igger tb
On the lid, ftra, maf housing and coupling you need atleast 100mm not to bottle neck it. The stock 90mm TB ported will work just fine. You might gain 0-4hp going to a 102mm. Remember the ls3 has no valve reliefs in the pistons so you cant go to crazy on the cam you will be limited to 230's duration unless you do some fly cuttin'.
mild head cam car with ud pully and stock ls3 intake you can expect around 510- 525 rwhp from my experience.
I also dont recommend home porting ls3 heads they are big enough as it is on the intake and you can do more harm then good. If anything touch up the exhaust side.
Old Jul 3, 2011 | 04:51 PM
lol are you crazy i aint touchin these heads......id be sending them out to get ported....which runs like 1100 or so.....i figured in the end by going with the crate motor, ill either break even in the long run, or save 500-1000. im really just trying to get a new motor in this car asap.....then i can do the other mods as i go......that being said, the cheaper way to go now is by going ls3 crate.
this is the prices im figuring. not including a tune or headers or anything, because id need them for each motor.
GOING THE LS3 CRATE ROUTE:LS3 crate motor plus shipping: 7000
cam-400
Ling conversion box: 200ish
other odds and ends: 400
TOTAL TO HAVE IT IN MY CAR RUNNING: 8000
GOING TSP FORGED 418:
motor with conversion kit and no shipping: $8550
reusing ls1 top end by going with ls6 heads: $0
shipping: 300ish
other odds and ends: $200
TOTAL TO HAVE IT IN MY CAR RUNNING: $9050
Now down the road. price for mods to be done
LS3 CRATE ROUTE:
advanced induction ported heads: $1400ish total
possibly fast 102/102: 1300
injectors: 400
fuel rails: 400
Total LS3 route: $11500
FORGED TSP ROUTE:
Fast 102/102 new: $1300
Injectors- $400
Billet fuel rail kit: $400
Total: $11150
so forged tsp is overall cheaper, unless i missed anything.......plus a lot stronger and will make about 40 more hp over the ls3 crate........so i see that it may be best in the long run now to just go tsp forged.....
Old Jul 3, 2011 | 07:28 PM
COPO9560's Avatar
In the long run going with a forged build will be your best bet. You should carefully consider using LS6 heads for a 418. The ported LS3 heads TSP offers will make more power than their LS6 offering. (ask them) Shop e-bay for an LS3 intake - there are usually a few on there for $300 including rails and injectors. You still need the TB but the small difference in cost will be made up in the power available.
As you are on a budget, before taking the engine plunge make sure you have added up the costs for everything else. Headers, exhaust, transmission upgrade, clutch or stall, 9 inch rear, suspension and brakes will add a ton of money to your build but really will be needed for a reliable fast car. Why have a lot of power if you can't use it.
Last suggestion - change your heater hoses when engine is out of the car. Simple thing to do that many forget and regret later.
Old Jul 3, 2011 | 08:03 PM
heater hoses? lol im lost.....yea came up to about 11000 for motor and 10000 for everything else.
Old Jul 4, 2011 | 09:29 AM
COPO9560's Avatar
Heater hoses will set you back about $10 if you reuse factory hard lines. They are real easy to get to with the engine out, real pain with it installed.
Old Jul 4, 2011 | 10:52 AM
heater hoses? im having a dumb momentt......they connect what to what
